How to Crush Limited-Time Challenges in Monopoly GO
Invisible
Сообщение Invisible »
Limited-time events in Monopoly GO are where true grinders shine. Whether it’s Sticker Boom, Wheel Boost, or High Roller Days, sprinting smartly can be the difference between walking away with scraps or completing your sticker album.
1. Time Your Sprint for Maximum Impact
Every event has power hours—usually the first 3 hours after launch and final 6 hours before it ends. These are when leaderboard activity spikes, so save your major push for these windows. It increases your chance of hitting high ranks before others adjust.
2. Use Multipliers Only When Rewards Are Worth It
That 10x or 20x multiplier looks juicy, but if the next reward tier only gives cash or common stickers, it’s not worth it. Wait until the tier reward includes dice or a rare pack before engaging high-speed mode.
3. Board Position Matters
Some events sync with specific boards—like landmark builds or rent challenges. Plan your sprint around boards where you can hit multiple rewards in fewer rolls. Always know which board gives the best return per dice spent.
4. Save All Packs for Sticker Boom
If the sprint overlaps with a Sticker Boom, you're in luck. You’ll double-dip by collecting event rewards and maximizing sticker value. If not, stash the packs and open when the next Boom hits.
5. Don't Waste Time Chasing the Final Few
If you're at the end of an event and still need 2–3 rare stickers, it might be more efficient to buy Monopoly GO stickers online from a trusted store like U4GM, rather than push through another 1,000 dice.
Вернуться в «Peugeot 107»
